Instantly extract effect sizes, F-ratios, and FDR-adjusted p-values from your models with the Calculate Effects Sizes extension, available now in the JMP Marketplace!
New to JMP? Join us Sept. 23-24 for the Early User Edition of Discovery Summit, tailor-made for new users. Register now for free!
Your voice matters! Tell us how you prefer to receive JMP updates, so we can tailor our communication to your needs. Take short survey.
Above is a picture of an attempt to Search for the beginning of the line of the 3 Column Names and Replace that with the prefix "Pre-" in JMP19. it causes my computer to start calculating who-knows-what for more than 20 minutes, before I finally decided to kill it. My computer heats up, the fan comes on and it sounds like it's in distress! I have to do something similar to this almost every day and have never had a problem in previous versions of JMP, where it usually finishes instantly. Is this a bug in JMP19? It is unusable to me if this is not fixed.
I have replicated your finding. After clicking on Replace All, it popped up the Replacing Data window. I waited a short bit of time and then Cancelled the operation, only to have a JMP Alert window pop up stating that over 21 million occurrences had been replaced.
Since I was only Searching on column names, and it was supposed to be restricted to the 2 selected columns, I think this is truly a bug.
Have you tried using Column Names -> Recode Column Names? It works just like Recode, so you can Replace String using regular expressions. It is working for me using "^" to insert at the beginning of the column name, in JMP 19.0.3.
creative approach by the #Learnbot - almost worth a submission to the wish list:
maybe oldname as a universal variable for the column name, allowing actions like Word(1,oldname), Left(oldname, 5), ... and the described concatenation.
Thanks for the suggestion. I showed a grossly simplified table, compared to what I normally work with. Many of my tables have thousands or 10s of thousands of columns, so renaming manually one by one is not an option. Certainly, I can write JSL code to do this. But S&R is a Windows standard forever and should work in JMP19. I have alerted [email protected] as @txnelson suggested. In the meantime I'll use JMP18.
Also, I did not find "Formula Column". I did find "Replace String", which allowed S&R on multiple columns. This worked. A bit mor work that a straight S&R but at lease it works.
Thank You for the suggestion. I often want to rename thousands or 10s of thousands of columns. S&R should work as it has up to JMP18. It's a bug that needs to be fixed. I contacted [email protected] and will use JMP18 in the meantime.
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '924262' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '924262') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '924262') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
