Why do I get an error
The following script was copied after doing a manual concatenation:
Add Properties to Table(
    {New Script(
        "Source",
        Data Table( "Data_W_Nov_15" ) << Concatenate(
            Data Table( "Data_E_Nov_15" ),
            Data Table( "Data_W_Jan_16" ),
            Data Table( "Data_E_Jan_16" ),
            Data Table( "Data_W_Feb_16" ),
            Data Table( "Data_E_Feb_16" ),
            Output Table( "Combined" ),
            Create source column
When I try to run it as a script I get the following error message. Why this error when didn't even change a single character.
Name Unresolved: Add Properties to Table in access or evaluation of 'Add Properties to Table' , Add Properties to Table(
    {New Script(
        "Source",
In the following script, error marked by /*###*/
    {New Script(
        "Source",
ms
Super User (Alumni) ms
Re: Why do I get an error
It looks like you have copied a table script. The actual concatenation script is the second argument of New Script( ).  If you choose to Edit the table script you'll see the code in the dialog. Select all and copy the script there to get a "ready to run" copy.
This part should work as intended:
