ChernoffTurtle7
Why can't use 'Fit Logistic 4P Rodbard' ?
hi, why does the option 'Fit Logistic 4P Rodbard' gray out in my JMP(16.1.0)? Anyone know the reason?Thanks!
Re: Why can't use 'Fit Logistic 4P Rodbard' ?
That model is disallowed when you have a dose equal to zero. Here is the result if that level is excluded and hidden:
Some analysts use log dose, which is missing for dose equal to zero. This model is available in this case, too:
ChernoffTurtle7
thank you very much!
