lwx228
Level VIII
Which JMP function can generate a non-repeating integer between two values?
I tried “Random Integer()”, but it produces duplicate integers. Thanks!
Re: Which JMP function can generate a non-repeating integer between two values?
I do not believe there is such a function in JMP, but it is very simple to create one
uniqueRandomInteger = Function( {n, min, max},
	{defaultlocal},
	hold = [];
	For( i = 1, i <= n, i++,
		val = Random Integer( min, max );
		While( N Rows( Loc( hold, val ) ) > 0,
		hold = hold |/ Matrix( val );
	hold;
x=uniqueRandomInteger(10,100,200)
gzmorgan0
@lwx228 ,
This is just an alternate method relying on the JMP function Random Shuffle
Names Default to Here(1);
ibeg = 257;
iend = 500;
random_all = As List( Random Shuffle( Transpose(ibeg::iend) ) );
//suppose you only want 100
vals = random_all[1::100];
show(random_all, nitems(random_all), iend-ibeg+1 );
show(vals, nitems(vals));
I felt like a slacker, given Jim's elegant function. [grin] The attached script includes a function that uses this range/shuffle/subset  method.  Jim, @txnelson,  your function name was spot on, so I used it.
 'Imitation is the sincerest form of flattery that mediocrity can pay to greatness.' - Oscar Wilde
	{defaultlocal},
	hold = [];
	hold;
gzmorgan0
@lwx228 ,
ibeg = 257;
iend = 500;
And another way:
Names Default to Here( 1 );
random order = Function( { min, max },
	min = Floor( min ); max = Floor( max );
	Index( min, max )[Rank( J( max-min+1, 1, Random Uniform() ) )];
Show( random order( 5, 10 ) );
