cormanaz
Where is transfer function analysis?
I have two pre-whitened series and I want to do a transfer function analysis on them using JMP 13.  The docs say there is one, but I can't find it.  It's not under analyze > speciailized modeling or the trangle menu for time series.  Where can I find it?
cormanaz
Re: Where is transfer function analysis?
I found the instructions in a reply here for anyone else looking for it.
cormanaz
I found it under the triangle menu for a series, but it's greyed-out. Specifically, I cut/paste both predicted series into a dataset, Invoked time series, put both series in the Y variables and got the analysis. So not sure how to proceed to enable the analysis.
cormanaz
David_Burnham
I expect you need one as Y and one as an input.  Take a look in the sample data under help and look for SeriesJ data.  It contains a table script that will launch time series with a transfer function.
-Dave
mani_av
I am facing the same problem
