  • Learn some foundational elements of JMP Scripting Language (JSL) and how to extend point & click automation into repeatable, shareable routines. Register. June 26, 2 p.m. US Eastern Time.
When a JSL code block crashes, is it possible to post a dialog box with a simple message?
I am trying to run a python script using JMP's Run Porgram to read a zipped file and parse the data. Occationally the Zip file has issues and python would through out an error message that " File is not a zip file"
Here is the JSL code block
rp = Run Program( executable( python_executable ), Options( {path_python_file, path_working_folder, path_datalog} ), readfunction( "text" ) );
When I execute the task from JSL I get the follwing error message.
is it possible to replace this error message with a simple error message such as " zip file import error"?
Thanks,
Shafi
Re: When a JSL code block crashes, is it possible to post a dialog box with a simple message?
You should be able to do it using Try(). This is also a good read regarding Throws and error catching in JMP  Scripting Guide > Programming Methods > Advanced Programming Concepts > Throw and Catch Exceptions
