miguello
What property would make window automatically stretch if I change size of display boxes within window?
I have GUI with multiple display boxes, some of them are Col List boxes that user can resize.
When they do that, window would make scroll bars. I don't want scroll bars. I want window to resize automatically to fit everything. Just like any platform (Fit Y by X for instance, does).
I can't find a combination of messages that would do that work... Can somebody point me in right direction?
Update:
Here is an illustration.
If you run this script:
bb = Border Box( Left( 10 ), Right( 10 ), Top( 5 ), Bottom( 10 ), Sides( 15 ),
clb = Col List Box( all, width( 250 ), maxSelected( 1 ) ),
nw = New Window( "Col List Box Example",
	bb
you'll get a window with a Col List Box.
If you try to resize this Col List Box beyond window, the window will expand.
But if you try to change the window size even a tiny bit - it won't respond to Col List Box changing size beyond window size. It will produce sliders.
In my Add-In my content for some reason does not fit vertically in the window.
The only way to fix that I was able to find was to change the size of the window. But now that we've changed the size of the window - it does not respond to changes in size of the content.
Is it a bug? Or is it expected behavior? Any way to fix that?
Re: What property would make window automatically stretch if I change size of display boxes within window?
As you are now resizing window and not the col list box, simplify your demo.
nw = New Window("",
	vlb = V List Box(
		tb = Text Box("Text"),
		hlb1 = H List Box(
			pb = Panel Box("Cast LUB",
				lub = Lineup Box(N Col(2),
					Button Box("Responses"),
					clb = Col List Box(dt
						, << Set N Lines(2)
Now start figuring out what is going on and why setting stretching here and there won't work and hopefully (by accident most likely, like I did) you come across that you have to remember set max size (and potentially min).
nw = New Window("",
	vlb = V List Box(
		hlb1 = H List Box(
						, << Set N Lines(2)
show(clb << Get Stretch, clb << Get Min Size, clb << Get Max Size);
clb << Set Stretch("Window", "Neutral");
clb << Set Max Size(10000, 100)
Maybe this is what you are looking for? Combination of Set Stretch with Fill/Window and Set Max/Min Size?
7 REPLIES 7
Very difficult to say as I'm not sure what issues you are having (adding scroll boxes isn't really a problem, they have a reason for being there most of the time). You do have << Set Stretch (or << Set Auto Stretching) which might work in some cases but it will also depend on how you have built your GUI.
I'm not exactly sure what you mean by Fit Y by X platform (report) automatically resizing to fit everything as in my opinion it doesn't do that. It does add scroll boxes when it is necessary. They are there for a purpose, if content doesn't fit inside the window let user still browse the content AND let them know something isn't shown. And if you mean launchers and how their col list box resizing resizes the window, it is most likely related to how you have built the GUI and they will also add scroll boxes if needed.
Edit:
For example "basic" launcher is much more dynamic if you use Lineup Box instead of V List Box + H List Box for button box and col list box combinations. And Lineup Box box generally makes your UI much cleaner due to it auto-sizing elements in each column and you can even control size over multiple lineup boxes by using Lineup Ruler Box.
nw = New Window("",
	H List Box(
		Panel Box("Select",
			Filter Col Selector(dt),
		Panel Box("Cast VLB + HLB",
			V List Box(
				H List Box(
					Col List Box(dt, << Set N Lines(2)),
				H List Box(
					Button Box("Features"),
					Col List Box(dt, << Set N Lines(10))
		Panel Box("Actions",
			Lineup Box(N Col(1),
				Button Box("OK"),
				Button Box("Recall"),
				Button Box("Close"),
				Button Box("Help")
miguello
Sorry for not being very clear. I was referring to the launch window of the Fit Y by X platform. Launch the platform, the window where you cast columns in roles. If you resize any of the Col List Boxes - window will resize accordingly without adding scroll bars.
My Add-In has a very similar launching platform, which would add scroll bars when I resize Col List Boxes.
Also, please check out an update on the question. The script i posted shows similar behavior.
On top of that, I found that it has something to do with the Taskbar autohiding on Windows: If I turn it ON, and my taskbar is hidden, my Add-In window opens up perfectly fitting all content. But as soon as I turn the autohiding off - window resizes to hide the bottom of content and vertical scroll bar appears. On top of that the bottom part of AddIn window doesn't even touch the taskbar. This is definitely a bug.
miguello
Here's the bottom part of my window with this page as the background. I have Taskbar autohiding ON. Everything is as I would expect.
As soon as I go to Windows Taskbar settings, and turn autohiding OFF, my window resizes so that a vertical scrollbar appears:
2025-01-31 23_27_28-What property would make window automatically stretch if I change size of displa.png
Screenshot positions are identical to the pixel. The only thing I did between them was unchecking the "Automatically hide the taskbar" in Windows settings. If I check it back in - it will revert to the first screenshot. Not that window isn't even touching the taskbar.
So, to solve this issue I had to explicitly set the window size. And this broke automatic window stretching when changing Col List Box just like in the script above.
miguello
This script has exactly the same problem as my small script in the update to the first message.
2025-01-31 23_34_34-What property would make window automatically stretch if I change size of displa.png
When you just run it and try to change Col List Boxes beyond the size of the window - the window stretches perfectly. But as soon as you try to change the size of the window itself by grabbing that corner with dots marked with red circle on the screenshot and move it even a couple of pixels - window stops responding to change is size of Col List Boxes and stops stretching, making scrollbars instead.
nw = New Window("",
	vlb = V List Box(
		hlb1 = H List Box(
						, << Set N Lines(2)
nw = New Window("",
	vlb = V List Box(
		hlb1 = H List Box(
						, << Set N Lines(2)
miguello
Well, it appears to be working in this simple case.
However, I tried exactly that and it didn't work in my way more complex GUI.
In any case this seems to be the solution, and I'll mark it as such, I just need to figure out how to apply it to my case.
You can skip the simple case if you think you can solve massive problem without first solving multiple smaller problems, most of the time it is impossible or will take unnecessary amount of time when compared to solving few small /simple problems which help you understand the problem.
How stretching works is heavily dependent on the structure you have built your GUI with. Again simple example even though I'm not sure how much you think they have value in them:
Both col list box will scale at the same time when using Lineup box and just setting stretching to one of them:
nw = New Window("",
	vlb = V List Box(
		hlb1 = H List Box(
					clb = Col List Box(dt,
						, << Set N Lines(2)
					Col List Box(dt,
						, << Set N Lines(2)
Same thing won't happen when using V List Box + H List Box
nw = New Window("",
	vlb = V List Box(
		hlb1 = H List Box(
				V List Box(
					H List Box(
							, << Set N Lines(2)
					H List Box(
						Col List Box(dt,
							, << Set N Lines(2)
If you had modified parent display box (panel box in this example) to not stretch, the child elements won't be stretching either
nw = New Window("",
	vlb = V List Box(
		hlb1 = H List Box(
						, << Set N Lines(2)
					Col List Box(dt,
						, << Set N Lines(2)
pb << Set Max Size(100, 10);
pb << Set Stretch("Off", "Off");
