What is the format for parameters for the Random Normal Mixture?
Suppose I want mean1 = 20, Mean2 = 40,  SD1 = 10, SD2 = 10, Probability1 = 0.8, Probability2 = 0.2.  How do I put these numbers in vectors for the "meanvec", "sdvec" and "probvec"?
ms
Super User (Alumni) ms
Re: What is the format for parameters for the Random Normal Mixture?
Random Normal Mixture([20, 40], [10, 10], [.8, .2])
Or if you want to use variables for the vectors
M= matrix(evallist({mean1 = 20, Mean2 = 40,  SD1 = 10, SD2 = 10, Probability1 = 0.8, Probability2 = 0.2}));
//Example
dt = New Table("Test",
    add rows(500),
    New Column("RNM", Formula(Random Normal Mixture(M[1 :: 2], M[3 :: 4], M[5 :: 6])))
dt << Distribution(Continuous Distribution(Column(:RNM)));
Thanks.  That works!
