MONOCup12
What is the best analysis to use for correlations between ''viscosity, ethanol, glycerol, sugar profile'' ?
I am interested to understand if anyone has used specific analysis for correlation between viscosity, ethanol, glycerol and sugar profile.
If you can recommend the right statistic analysis, will be amazing.
Victor_G
Re: What is the best analysis to use for correlations between ''viscosity, ethanol, glycerol, sugar profile'' ?
Hello @MONOCup12,
Welcome in the Community !
The first platform that can be helpful to look at correlations between variables is the Multivariate platform. You can visually inspect correlations between all pairs of variables, create correlation heatmaps and calculate parametric and non-parametric correlation statistics, like Spearman's coefficients and others.
Victor GUILLER
Victor_G
Hello @MONOCup12,
Victor GUILLER
MONOCup12
Thank you so much for this. This is confirming what I was reading last week in regards correlations and best ways to see that.
