See how to use to use Text Explorer to glean valuable information from text data at April 25 webinar.
What is a correct way to deal with missing fonts?
miguello
Let's say I wrote a beautiful script, that uses some fonts - standard fonts you'd find on almost any computer, but not the JMP default fonts.
I distributed this script to my users, and I started getting feedback on errors messages about missing fonts.
It appears that there are computers in the organization that have a very minimal number of fonts installed.
So I wrapped each Font message in Try() statement, like so:
biv = dt << Bivariate( Y( :height ), X( :weight ) );
rbiv = biv << Report;
Try((rbiv << XPath( "//AxisBox/MouseBox/DropBox/TextEditBox" )) << Set Font( "Agency FF", 13 ), Write("No Font"));
The problem is it still gives me an error pop-up.
How do I correctly script the following:
If a Font is installed - set to the GUI elements as directed, otherwise - use the default font.
Re: What is a correct way to deal with missing fonts?
This will work, and give you an indication if the <<setfont failed
Batch Interactive( 1 );
x = Log Capture( ((rbiv << XPath( "//AxisBox/MouseBox/DropBox/TextEditBox" ))) << Set Font( "Comic Sans MS1", 13 ) );
Batch Interactive( 0 );
if(x!="",Show( x ));
Note there is no try(...) because <<setfont is not throwing an error. I think the dialog is for a warning, not an error, and should probably be removed, just leaving a warning in the log. LogCapture is making the <<setfont complete before the clearing of the Batch Interactive flag. Without LogCapture, the behavior is wrong.
Away from my computer, but I believe the answer is to use the batch interactive flag to suppress the dialog. I think the flag is still undocumented and you'll have to search within this community to see how it works. You may also find it useful to use the log capture function to grab the text that would be in the dialog in order to diagnose what has happened, or you may be happy with the default font that you get anyway.
edit: link to Wendy's note about Batch Interactive
miguello
I was only able to find one post about Python with this piece of code without much explanation:
# Set the matplotlib.pyplot interactive flag to false
_JMPpp.interactive(False)
Any help would be much appreciated.
How do I prevent JMP Alerts from popping up?  is a starting point, not the best...
There is a function,
batch Interactive(1);
that sets JMP into batch mode which assumes no user is at the keyboard and takes the default button answer. This is a little undesirable in interactive mode because you might not notice a message in the log. You can set it to 0 right after the statement that might trigger a semi-expected but unwanted dialog.
Each call also returns the previous value if you want to use a stack-like mechanism for restoring the value.
miguello
Strangely, this doesn't work:
Batch Interactive(1);
Try((rbiv << XPath( "//AxisBox/MouseBox/DropBox/TextEditBox" )) << Set Font( "Agency FF", 13 ), (rbiv << XPath( "//AxisBox/MouseBox/DropBox/TextEditBox" )) << Set Font( "Agency FB", 13 ));
Batch Interactive(0);
while this works:
throw("Test");
Very odd. I think the next best answer is to comment out the Batch Interactive(0).
show(Batch Interactive(1));
((rbiv << XPath( "//AxisBox/MouseBox/DropBox/TextEditBox" ))[1]) << Set Font( "Comic Sans MS1", 13 );
//show(Batch Interactive(0));
I can't explain what is happening, but I think it might be because the font isn't tested until needed...but I can't figure out how to do a wait(1) that fixes it.
Edit: sent a note to the dev team.
Edit2: next idea is better...
miguello
Looks like this works in this example. Let me see how it will look like in a real life script.
