JK_PC
Well-Trace Add-in Available for JMP17 Upgrade?
I just received notification to upgrade my JMP software. Before I install it, curious if installing this software upgrade will have any implications to the application of the “Well-Trace Add-in” that I use in my current JMP16 version? Would I have to request the Well-Trace Add-in once I install JMP17?
Jeff_Perkinson
Re: Well-Trace Add-in Available for JMP17 Upgrade?
I assume you're talking about Plot a well trace in 3D using directional survey data.
Your best avenue is to add a comment on the add-in post directly and the author will get a notification with the question.
-Jeff
Jeff_Perkinson
-Jeff
I've tested out the Well Trace Add-in in JMP 17 without any issues. Please note that the add-in will only launch if a data table is already open.
