Weekly Filter
JohannesENS
Hello everybody,
i do have a column in the following format: dd/mm/yyyy hh:mm:ss
I want do add a filter which shows only the last seven days.
Is there a possibility to do this? Unfortunately, I have no experience in scripting/JSL.
Thanks in advance.
Re: Weekly Filter
I still have no idea how you want to use this "filter", so I cannot really provide more information.
I have attached modified version of JMP's sample data table Big Class with dates.
It has date column (generated with formula) and column which should tell if date is in last 7 days (also formula)
There is also table script which will create graph builder to with local data filter
Re: Weekly Filter
Filter with week number (and year) or last seven days? And if last seven days which date should it be based on?
JohannesENS
Re: Weekly Filter
Filter last seven days based on current day.
Re: Weekly Filter
Not sure where the filter will be, but you can get the date for example with something like this:
new_date = Today() - In Days(7);
new_date = new_date - Time Of Day(new_date);
As Date(new_date); //13May2022
JohannesENS
Re: Weekly Filter
Thank you. But where to paste this?
Re: Weekly Filter
JohannesENS
Re: Weekly Filter
Thank you!
No recommendations found
