shampton82
Way to move a window into a "child" poistion on the home window?
Hey everyone,
I was wondering if there was a way to script in moving a "New Window" as a "child" of the data table, like a normal analysis widow shows up as:
I'd like this window to show up under the data table it is working with
So under the graph builder icon.
Thoughts?
Steve
Re: Way to move a window into a "child" poistion on the home window?
I know at least of one workaround for this as I have used in other case. You can add report to your new window and then collapse it
gb = dt << Graph Builder(
	Variables(X(:weight), Y(:height), Overlay(:sex)),
	Elements(Points(X, Y, Legend(9)), Line Of Fit(X, Y, Legend(11)))
nw = New Window("not child",
	Button Box("OK")
nw = New Window("is child",
	vlb = V List Box(
		Distribution(Nominal Distribution(Column(:sex)), Histograms Only)
	Button Box("OK")
vlb << visibility("Collapse")
My topic where I asked how to force associated data for new window: What determines which data table is seen as "Associated Data" for New Window?
Wish list item: Allow setting associated data table(s) to a new window
Level XIII
And if you want to move an existing window into a child position, you can just add a temporary report and then delete it again.
After executing the code, the report will show up as a child of Big Class:
nw = New Window("change to child",
	V List Box  (
	tmp= v list box (),
	Button Box("OK"))
tmp << append (
wait(0);
tmp << delete;
	Button Box("OK")
	vlb = V List Box(
	Button Box("OK")
Level XIII
	V List Box  (
	tmp= v list box (),
	Button Box("OK"))
tmp << append (
wait(0);
tmp << delete;
