Dave0416
Want to create table showing all possible combinations from x & y position vectors
I am provided 2 position vectors xpos and ypos.  I want to create table showing all possible combinations from the x & y position vectors. I'm showing a very simple example where I want to create 2 new vectors containing all possible combinations. My issue appears to stem from the indexing but I'm stumped.
// Want to create table showing all possible combinations from x & y position vectors
xpos={1, 2, 3, 4, 5};
ypos={7, 8, 9 };
xloc={};
yloc={};
// Loop through x positions
for(i=1, i<=NItems(xpos), i++,
	// Loop through y positions
	for(j=1, j<=NItems(ypos),j++,
		insert into(xloc, xpos);
		insert into(yloc, ypos, j);
	//print(i);
xloc;
yloc;
dt = new table("All Combos");
dt << new column("X", continuous, values(xloc));
dt << new column("Y", continuous, values(y));
	Want a table that looks like this:
	X	Y
	1	7
	1	8
	1	9
	2	7
	2	8
	2	9
	5	7
	5	8
	5	9
Re: Want to create table showing all possible combinations from x & y position vectors
I would just use
     Tables=>Join
and use the Cartesian Join capabilities to get what you want.
names default to here(1);
ypos={7, 8, 9 };
dt1 = new table("One", new column("x"));
dt1:x << set values(xpos);
dt2 = new table("Two", new column("y"));
dt2:y << set values(ypos);
dtCart = dt1 << Join(
	With( dt2 ),
	Cartesian Join,
	Output Table( "Final" )
I would just use
     Tables=>Join
ypos={7, 8, 9 };
	With( dt2 ),
	Cartesian Join,
Dave0416
Thank you! I got so wrapped around the axle that I forgot about your solution. Can I blame my lapse on today being Monday?
