SpannerHead
Wafer Maps
I have been drawing wafer maps in Graph Builder using Customize Graph.  One issue I have is that the custom outline I have remains static in the frame, whereas the die can move depending on where they are populated.
For example, if I only test a few die, their location appears to relocate to the bottom and left relatively to the drawing.
Aside from adding bogus data to occupy the previous extremities, is there a way to have the relationship remain fixed?  The code contained in the Customize Graph Script is as follows.
Transparency( 0.5 );
Fill Color( "Gray" );
Oval( -1, -1, 7, 7, 1 );
Pen Size( 2 );
Line( [-1, -0.855, -1], [2.75 3 3.25] );
Pen Color( "Black" );
Pen Size( 2 );
Oval( -1, -1, 7, 7 );
Pen Size( 1 );
Line Style( "Dotted" );
Oval( -0.9, -0.9, 6.9, 6.9 );
Transparency( 1 );
Fill Color( "White" );
Polygon( [-1, -0.855, -1], [2.75 3 3.25] );
Line Style( "Solid" );
Fill Color( 1 );
Rect( 1.5, -0.5, 4.5, 0.5 );
Rect( 0.5, 0.5, 5.5, 1.5 );
Rect( 0.5, 1.5, 5.5, 2.5 );
Rect( -0.5, 2.5, 6.5, 3.5 );
Rect( 0.5, 3.5, 5.5, 4.5 );
Rect( 0.5, 4.5, 5.5, 5.5 );
Rect( 1.5, 5.5, 4.5, 6.5 );
Rect( -0.5, 2.5, 0.5, 3.5 );
Rect( 0.5, 0.5, 1.5, 5.5 );
Rect( 1.5, -0.5, 2.5, 6.5 );
Rect( 2.5, -0.5, 3.5, 6.5 );
Rect( 3.5, -0.5, 4.5, 6.5 );
Rect( 4.5, 0.5, 5.5, 5.5 );
Rect( 5.5, 2.5, 4.5, 3.5 );
Slán
SpannerHead
15 REPLIES 15
Level XIII
Re: Wafer Maps
Re: Wafer Maps
@hogi  - yep.  There was a bug where occasionally it would get confused and kick over into Geodesic - but, I haven't run into it in a long time. I've been using shape files with the STK for 10 years now without any consistent issues. I've been testing and working on the new version of the toolkit for 6 months now on JMP 19 and haven't run into the bug once.
M
Level XIII
Re: Wafer Maps
Ah, just an issue when adding Background Maps : )
Luis_HC
Re: Wafer Maps
I've used STK's Build Shape Files function, Use Die Index if I recall correctly, to generate shape files. When I apply the Background Map produced by the shape file, the axes change to geodesic even though I've set linear scale for the Axis column property in the coordinate system of the shape file and the Axis column property of the data files.
Re: Wafer Maps
Yep - that's the bug - I'm taking a different approach with the JMP 19 version.  It doesn't have the same problem.  I'm doing all the background maps, etc. programmatically.  Since I haven't run into that in a long time, I'm guessing the issue is either fixed or I'm circumventing it.
Regardless, be sure to report it to tech support as a bug (it's not a feature!) along with the steps to reproduce.
M
Re: Wafer Maps
@MikeD_Anderson ,
Solely adding to this post to tell you that that looks awesome! Excited to see it in action
Thanks,
Ben
