hogi
Level XIII
Variations of the SILENT IGNORE Trap
In some cases, JMP makes it very hard for a user (or AI) to debug the code.
from: https://community.jmp.com/t5/Discussions/AI-scripting-misleading-log/m-p/929994/highlight/true#M1086...
 @Craige_Hales wrote:
objects ignore messages they don't understand
hogi
Level XIII
Re: Variations of the SILENT IGNORE Trap
From the original post: AI scripting - misleading log ...
kd = dt << KDTable("hello");
result = kd << K Nearest Rows(1, 3);print("finished");
JMP complains about line 3 :
Object 'Data Table' does not recognize the message 'K Nearest Rows'
the actual error in line 2 is silently ignored.
hogi
Level XIII
Move Table Script: 1st argument must NOT be a variable
script_name = "test";
dt << New Script( script_name, "1" );  //no issue with the variable
myGroupName = dt << group scripts( today_str, script_name );
// No issue with the variable - even without a list
dt << Move Selected scripts( script_name, after( "Distribution" ) );
//doesn't understand the variable -> silent ignore
