cerdmh
Variability chart - Remove ref line
Hi
I'm trying to remove ref line from variability chart.
In previous JMP version the below script worked.
can any know why not working on JMP16.
biv = Bivariate( Y( :weight ), X( :height ), );
rbiv = biv << report;
axisbox = rbiv[axis box( 1 )];
axisbox << Add Ref Line( 90, "Dashed", blue ); //Works
axisbox << Remove Ref Line( 90 ); //Don't work
Thanks
Re: Variability chart - Remove ref line
I have replicated the issue you specified.  Please report the issue to
     [email protected]
This is a known bug. It was previously reported to Technical Support. They entered it into our tracking system for a fix. The fix is applied to a maintenance release. If you cannot wait for the release, there is a work-aournd:
axisbox << Add Ref Line( 90, "Solid", "Blue", "", 0 ); // replace with zero width instead of remove
cerdmh
Thanks for your support
statman
Thanks for bringing this up.  It was "bugging" me also...I kept reverting to JMP 15 for these charts.
