cerdmh
Variability chart - Remove ref line
Hi
I'm trying to remove ref line from variability chart.
In previous JMP version the below script worked.
can any know why not working on JMP16.
biv = Bivariate( Y( :weight ), X( :height ), );
rbiv = biv << report;
axisbox = rbiv[axis box( 1 )];
axisbox << Add Ref Line( 90, "Dashed", blue ); //Works
axisbox << Remove Ref Line( 90 ); //Don't work
Thanks
Re: Variability chart - Remove ref line
I have replicated the issue you specified.  Please report the issue to
     support@jmp.com
This is a known bug. It was previously reported to Technical Support. They entered it into our tracking system for a fix. The fix is applied to a maintenance release. If you cannot wait for the release, there is a work-aournd:
axisbox << Add Ref Line( 90, "Solid", "Blue", "", 0 ); // replace with zero width instead of remove
cerdmh
Thanks for your support
Thanks for bringing this up.  It was "bugging" me also...I kept reverting to JMP 15 for these charts.
