rshehadah
Variability Chart
I have a variabilty chart with 100 lots. I was wondering how can I order the lots by starttime? If variabilty chart is not the best to show this, what would you recommend?
This lots are also broken down by different blends.
The x grouping is lots then blend.
Thank you,
Rami
Re: Variability Chart
1. sort the data by starttime.
2. Set the column property "Row Order Levels" for the lot column.  This will force the Variability Chart to order the lots in the physical order it see them, and since the data are sorted by starttime, the lots will be in starttime order
