LNitz
Using the SAS Variable Labels in Table Output
I built a Federal Reserve System exercise from the Sudrvey of Household Economic Decision Making data set--300 + variables and 11K cases.  The SAS (and STATA) varuable names represented in the codebook and in the data set are four characters long, and a only a bit mnemonic. The variable labels are a sentence derived from the question.  Importing the table from SAS to JMP  using variable laels would render output unprintable because of the length of the variable labels. Using the table with the original namee, however, is a far reach for students--i reqires reopening the codebook or the Column column to see the variable label. Then the variable label must somehow be handled by hand in the final analysis output, perhaps by dumping it to  Excel and then to introudce meaningful column names.
Proposals to hand edit the column characteriistic page to paste the variable label into the variable name block, with whatever kind of editing are pushing the limits for undergraduate work expectations.  Writing or even copying and executing JSL code is beyond the reasonable expectations for the class.
Is there a cleaner way to represent  the output rows and columns with some version of the variable label, without requiring JSL or cutting and pasting.  The other option, reimport the file fro the SAS file, using the column labels as column names coming into JMP   would still produce a file with 30 character column names.
Re: Using the SAS Variable Labels in Table Output
You could use Short Name / Long Name column properties Using JMP > Set JMP Column Properties > Column Properties in JMP > Properties That Attach Informatio... .
Or Recode Multiple Column Headers with mapping table. And maybe share some simple script/workflow to the students which can assist with these things.
dlehman1
Just guessing here, but this seems like the kind of tedious thing that AI excels at.  If the awkward list of lengthy names is submitted as a spreadsheet or text file, you might get AI to do the translation work required to get intelligible variable names.
