Hi @ConvolutionOx19
I'll take the JSL from the post you've put and annotate it just to make it clearer what you need to do (essentially just copy paste your fit model details):
// example
dt = Current Data Table();
///////////////////////***********CHANGE THIS BIT **************////////////////
// fit least squares with studentized residuals
obj = dt <<
//////COPY PASTE YOUR FIT MODEL TEXT HERE///////////////
Fit Model(
Y( :ABRASION ),
Effects( :SILICA, :SILANE, :SULFUR ),
Emphasis( "Minimal Report" ),
Run(
:ABRASION << {Summary of Fit( 1 ), Analysis of Variance( 1 ),
Parameter Estimates( 1 ), Scaled Estimates( 0 ),
Plot Actual by Predicted( 0 ), Plot Regression( 0 ),
Plot Residual by Predicted( 0 ), Plot Studentized Residuals( 1 ),
Plot Effect Leverage( 1 ), Plot Residual by Normal Quantiles( 0 ),
Box Cox Y Transformation( 0 )}
//////////////////END OF COPY PASTE//////////////////////
// access report layer
rpt = obj << Report;
// access plot frame
frame = rpt["Studentized Residuals"][FrameBox(1)];
// access line segments in plot frame
line = frame << Find Segs;
// ask for value of line representing Bonferroni limits (only positive necessary)
bonferroni = (line[2] << Get Y Values)[1];
// display limit in Log
Show( bonferroni );
To paste the right details, fit your model, go to the red triangle options on the top of the model page and get 'save script > to clipboard'.
Thanks,
Ben
