miguello
Using "Get Rows Where"
I need to use Get Rows Where to get the row with value that is just below certain value.
In other words:
I have a Date A
I have a table with dates. I need to get the row where the date is the latest, but less than Date A
Example:
I have a date when person died.
I have table with all event when somebody logged in into his account. There are dates before and after his death.
I need to find the latest date he logged in before his death.
Something along the lines of:
lastSelfLogin = dt<<Get Rows Where(:loginDate < deathDate & /*here goes condition that this date needs to be the last*/);
Any ideas?
Thanks!
Re: Using "Get Rows Where"
This will do it:
     lastSelfLogin = Max(dt<<Get Rows Where(:loginDate < deathDate));
miguello
Jim,
Thanks for the reply.
I was little bit incorrect in giving my example. Your script indeed will give the latest date of self login. However, I needed the number of row, when it happened, to find other associated values from neighbouring columns.
The solution is following:
	//Finding indices for all the logins for current person before death date
	rowPerson=dt2 << Get Rows Where(:Person==thisPerson & :"DeathDate" < thisDate);
	//Finding index for the latest login date
	rowLatestLoginDate=Loc(loggedOn[rowPerson] == Max(loggedOn[rowPerson]));
//Then later I can access other columns. For instance, weather when person logged in himself for the last time
lastWeather=currentWeather[rowPerson[rowLatestLoginDate]];
I am glad that you found your solution
