wyatt_dunn
Using loop variable as column input
I am wondering if it possible to use my for loop variable, i, as an input for a new column, depending on the value of another column.  Here is what I am thinking, but cannot get to work.
dt << New Column("Site", Numeric, Formula(
   For(i = 1, i <= 8, i++,
      If(Contains(:Column1, i), i);
Re: Using loop variable as column input
You certainly can.  The only issue you have is that the Contains() function is a character handling function, and the arguments passed to it must be character(string) values.  I am assuming :Column1 is a character column so all you need to do is to convert the index variable "i" from a numeric to character
      If(Contains(:Column1, char(i) ), i);
pauldeen
What is it your a trying to do, do you have some example data?
Do you want to copy the value of Column1 to another column?
Do you want to take the value from another column based on the numeric reference in column1?
