Ryan001
Cannot set the specification limit attribute (USL/LSL) for each column
dt = Current Data Table();
dt << Begin Data Update();
For( i = 9, i <= N Cols( dt ) - 1, i++,
col = Column( dt, i );
// 获取第二行和第三行的数据作为规格限
lowerLimit = col[2];
upperLimit = col[3];
show (lowerLimit);
show(upperLimit); // checked the log, the result is ok.
// 设置规格限属性
col << Set Property( "Spec Limits", {LSL(lowerLimit), USL(upperLimit), Show Limits( 1 )} );
dt << End Data Update();
Re: Cannot set the specification limit attribute (USL/LSL) for each column
You will have to evaluate the values to columns, below is an example
lowlimit = 50;
highlimit = 100;
Eval(EvalExpr(
	Column(dt, "height") << Set Property(
		"Spec Limits",
		{LSL(Expr(lowlimit)), USL(Expr(highlimit)), Show Limits(1)}
Insert one expression into another using Eval Insert, Eval Expr, Parse, and Substitute
