Newbie2Jumpie
Using current date (TODAY() as macro variable entry for naming a dataset (scripting)
I would like to use TODAY() to derive the current date and use it as a timestamp in naming a  JMP dataset, and as a TIME_STAMP column as well. In SAS, it may look like this (I admit I neglected the formatting a bit).
%let TODAYDATE=today();
data WORK.CLASS_&TODAYDATE. ;
set SASHELP.CLASS;
TIME_STAMP = &TODAYDATE.  ;
run ;
After resolving, the result should look like this :
"WORK.CLASS_20190628"
and
"TIME_STAMP
20190628
20190628
20190628
20190628
May JSL macro variables do the same job?
Any input greatly appreciated.
Have a nice weekend!
Newbie
Re: Using current date (TODAY() as macro variable entry for naming a dataset (scripting)
The following will create a new table with the name specified as you requested.
New Table("CLASS_" || format(today(),"yyyymmdd"));
Newbie2Jumpie
That's grand, that is!
Thanks a lot, mate!
