Predict with CI's from Passing-Bablok under Method Comparison add-in
Jun 24, 2019 07:42 AM(3496 views)
I am using the Method Comparison Add-in by Russ Wolfinger to fit a Passing-Bablok regression. The add-in works great because it also adds CI's for the regression estimates. It also computes an additional orthogonal fit for comparison.
Now I am trying to calculate the predicted value at a given X point, with Confidence Intervals using the PB fit. Is there a way to do this?
Not sure, however you may want to ask Russ directly in the reply of the add-in download page, if this can be added. If so, it would be great to add the response (or link it to) here.
/****NeverStopLearning****/
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '214289' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '214289') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '214289') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
