Mad_dog_550
Using a variable for multiple commands
Hi All,
I am looking for a way to use one variable in place of the individual commands in place of the multiple command lines. When I run this the Stacking window opens rather then executing the other commands included in the variable. I've also tried using combinations of EVAL() and PARSE() but with no better results.
I apologize if the terminology I've used isn't correct.
Thanks for any help!
test_variable = "columns( :Column1, :Column2 ),
	Source Label Column( \!"Label\!" ),
	Stacked Data Column( \!"Data\!" ),
	Move Columns( To First ),
	Output Table ( \!"Test Output Table\!" )";
current data table () << Stack (test_variable);
Level XII
Re: Using a variable for multiple commands
@jthi wrote:
Usually you can build them in other ways (expressions) than using just strings (and I would say if you can, you should).
One approach is to use a placeholder ( _cols_ ) - and then replace (substitute) it with your pre-configured expression - like here:
Names Default to Here(1);
cols = Expr(Columns(:height, :weight));
mycommand = Expr(current data table () << Stack (_cols_, Source Label Column( "Label" ),
	Stacked Data Column( "Data" ),
	Output Table ( "Test Output Table" )));
Eval (Substitute ( Name Expr(mycommand),Expr(_cols_), Name Expr (cols) ))
Some Expr() and Name Expr() "magic" is necessary to prevent JMP from executing expressions at the wrong time [Expr()] -  and to get access to the expression (Name Expr()) which is stored inside a variable (name) instead of the name itself.
At first sight, a user will decide that it's better to live without this overhead - or to use Eval(Parse(String)) as a fallback solution. But it's a good idea to invest some time here, e.g. with the help of this great lecture:
Using JSL to Develop Efficient, Robust Applications (EU 2018 415)
What are you trying to do exactly? Use same selections in stack multiple times?
Mad_dog_550
I picked the Stack because it seemed like a simpler example of what I was trying to accomplish.  Ultimately, I wanted to use a variable to be used as a substitute for a block of command text in formatting a bunch of control charts.
Level XII
