This widget could not be displayed.
Created:
Jun 24, 2010 10:43 AM
| Last Modified:
Jun 24, 2010 7:43 AM
(5720 views)
| Posted in reply to message from 06-23-2010
I'd have thought the journal would provide a mechanism to collate a sequence of analyses that you'd find difficult to combine any other way: I tried to do something very similar myself using the journal a while back in JMP 7, and discovered that controlling the size of the charts in the Word document was difficult, as most of the time all the outputs were shrunk to fit the entire journal onto a single page. Since then I've upgraded to JMP 8.0.2, and have just tried running the following script, which now seems to run fine. All three output formats appear identical in MS Word except for the page break, which seems to be lost in HTML:
