This widget could not be displayed.
Created:
Jul 20, 2010 04:56 AM
| Last Modified:
Jul 20, 2010 1:56 AM
(3697 views)
When using the Stepwise platform, JMP helps you to make the model with the best R² / R²adj.
I would like to get the model with the best PRESS criteria (Predicted Error Sum of Squares). How would it be possible to do that?
I know you can get the PRESS information once the model is built, but I would like to be sure I am building the model with the best PRESS as possible.
Thank you for your help.
