alexbnieto
Using Graph or GraphBox - How to change X,Y axis increment & Reverse axis
I am trying to use the Graph function but am unsuccessful in making X-axis incremements of 1 and Reversing Y-axis order.
I tried swapping the numbers in the Y Scale properties but no luck. Only way to change is to physically change graph manually. Still unable to figure this out using JSL.
Any help is appreciated!
Here is a snippet of my code
New Window( "Map",
Graph(
Frame Size( 800, 800 ),
X Scale(-0.6, 40.7),
Y Scale(0.4, 7.6),
ms
Super User (Alumni) ms
Re: Using Graph or GraphBox - How to change X,Y axis increment & Reverse axis
Send the commands to each AxisBox(). Use <<show tree structure if uncertain about the naming or numbering of the display boxes of interest.
An example:
nw = New Window("Map",
    Graph(Frame Size(800, 800), X Scale(-0.6, 40.7), Y Scale(0.4, 7.6))
// nw<<show tree structure();
nw[AxisBox(1)] << reversed scale;
nw[AxisBox(2)] << inc(1);
