ileshem
Change the X axis label orientation to be angled as a default
Hello again,
For "fit Y by X", Is there a way to change the X axis label orientation to be angled as a default, instead of me needing to change it every time?
Thanks again.
Re: Change the X axis label orientation to be angled as a default
I looked in Preferences for Graph, Style and the Bivariate Platform, and found no reference to setting a preference for the angled axis values.
Maybe someone else has a solution
