tobben24
Use two columns to set a range(start and stop) where y-value is valid
Title was maybe a bit badly explained, but below I added a simple csv example and a visio plot illustrating what I want. Not sure what to call this kind of plot, or how to use two columns to set a range(start and stop) where y-value is valid.
CSV:
Column Y;Column X0;Column X1
20;0;5
30;10;15
thickey1
Re: Use two columns to set a range(start and stop) where y-value is valid
1. Add group column
2. Stack Table by X1,X2
3. Make Overlay Plot
4. Overlay Groups
5. Connect Through Missing
May not be the most elegant but kinda gets you what you described
Read in the data into JMP
Stack the data either interactively or with the script
Data Table( "Untitled 4" ) << Stack(
	columns( :Column X0, :Column X1 ),
	Source Label Column( "Label" ),
	Stacked Data Column( "Data" )
Then run graph builder interactively or by using the script below
Graph Builder(
	Variables( X( :Data ), Y( :Column Y ), Overlay( :Column Y ) ),
	Elements( Line( X, Y, Legend( 5 ) ) ),
		Dispatch(
			"400",
			ScaleBox,
			{Legend Model(
				5,
				Properties( 0, {Line Color( 20 )} ),
				Properties( 1, {Line Color( 20 )} )
thickey1
1. Add group column
4. Overlay Groups
tobben24
Thanks for your reply, I have now managed to do what I wanted:)
Graph Builder(
		Dispatch(
			"400",
			ScaleBox,
			{Legend Model(
				5,
tobben24
Thanks for your reply as well, as written above I have now managed to do what I wanted:)
