the_qrv
Use of N Categories(:column) from Summary table for script computations
Hi, I would like to inquire how to make use of N Categories(:X) resut in summary to make mathematical operations via script. It seems the :N Categories (:column) can not be used directly to do the computations, even if I rename or make another numeric column, blk_count. Here is what i have:
dt_ax = dt_X << Summary (
          Group (:abx),
          N Categories (:blk),
          Link to original table (0));
dt_X << Update (
          with (dt_ax),
          Match Columns(:abx = :abx),
          Ignore missing);
close(dt_ax, no save);
dt_X << New column("blk_count",
          Numeric,
          continuous,
          << set each value(blk_count == :N Categories( :blk ));
Appreciate all your inputs! Thanks in advance!
Byron_JMP
Re: Use of N Categories(:column) from Summary table for script computations
This will give you the number of levels for a specified column:
dt_X<<new column("N Levels of blk", formula(
Summarize( x = by( :blk ) );
N Items( x );));
If you wanted to know how many rows are in each level then the Col Number function work:
Col Number( :blk, :blk )
Byron_JMP
N Items( x );));
the_qrv
Thanks Byron for the help!
