terapin
Use date variable in Open Database JSL command
I have a JSL script that opens a SQL database and then processes the data for various purposes.  My challenge is passing a date variable to the Open Database command to further refine the automation of the process.  I've tried a whole host of options for trying to do this, but nothing has worked so far.  Does anyone have any suggestions for how I can replace the Date_Time value listed in the Open Database command with the variable datetime shown below?
datetime = "2021-08-01";
// Program opens diagnostic SQL data table for all instruments
dt.db_diag = Open Database(
"DSN=AQM;Description=AQM;UID=sa;PWD=LKJDFDF;Trusted_Connection=No;APP=JMP;WSID=TESTPC;DATABASE=EnvidasConfig;",
"SELECT * FROM [dbo].MonitorDiagnosticsData WHERE Date_Time >= '2021-08-18'"
Re: Use date variable in Open Database JSL command
See if this will do what you need
Eval(
	Parse(
		"dt.db_diag = Open Database(
\!"DSN=AQM;Description=AQM;UID=sa;PWD=LKJDFDF;Trusted_Connection=No;APP=JMP;WSID=TESTPC;DATABASE=EnvidasConfig;\!",
\!"SELECT * FROM [dbo].MonitorDiagnosticsData WHERE Date_Time >= '"
		 || datetime || "'\!"
Eval(
	Parse(
		 || datetime || "'\!"
terapin
That works perfectly,
I also now see where I was putting the ' in the wrong location during my testing.  Thanks for the quick and helpful reply.
