robot
Use Variable Columns in Platform Script
I encounter an error when trying to use variable columns in the Split platform.  Does anyone know why this is not working, and how to resolve it?  JMP 18.2.0.
// These all work.
dt << Split( Split By( :sex ), Split( :height, :weight ), Group( :name, :age ), Output Table( "Split of Big Class 1" ) );
dt << Split( Split By( :sex ), Split( {:height, :weight} ), Group( {:name, :age} ), Output Table( "Split of Big Class 2" ) );
dt << Split(
	Split By( Column( dt, "sex" ) ),
	Split( Column( dt, "height" ), Column( dt, "weight" ) ),
	Group( Column( dt, "name" ), Column( dt, "age" ) ),
	Output Table( "Split of Big Class 3" )
dt << Split(
	Split( {Column( dt, "height" ), Column( dt, "weight" )} ),
	Group( {Column( dt, "name" ), Column( dt, "age" )} ),
	Output Table( "Split of Big Class 4" )
// This does not work.
split_by_col = Column( dt, "sex" );
split_cols = {Column( dt, "height" ), Column( dt, "weight" )};
group_cols = {Column( dt, "name" ), Column( dt, "age" )};
dt << Split( Split By( split_by_col ), Split( split_cols ), Group( group_cols ), Output Table( "Split of Big Class 5" ) );
Re: Use Variable Columns in Platform Script
The list needs to be evaluated.
dt << Split( Split By( split_by_col ), Split( eval(split_cols) ), Group( eval(group_cols) ), Output Table( "Split of Big Class 5" ) );
