FN
FN
Use JMP Locale Settings( 0 ) not working on macOS
It seems the following command does not work for JMP MacOS.
Is there a general script to deal with the following scenario? Or do we need to put conditionals depending on the OS of the user?
// Configuring JMP to save CSV as commas and not
	If( (Num( "3.14" ) == 3.14),
		is_EN_num_format = 1, //"English numeric format"
		is_EN_num_format = 0 //"Non-english");
	If( is_EN_num_format == 0,
		Preferences( Use JMP Locale Settings( 0 ) ));
// code
// Setting back the formatting of numbers to its original
	Preferences( Use JMP Locale Settings( 1 ) ));
0 REPLIES 0
