Share your ideas for the JMP Scripting Unsession at Discovery Summit by September 17th. We hope to see you there!
joickle
Update existing table with new data without creating output table
I am trying to write a script that will update my existing table without producing an output table.  I have the following code which doesn't seem to work:
Data Table("Crea Table") << Update from Database(
"DRIVER=SQL Server Native Client 11.0;SERVER=REMOVED FOR SECURITY;",
"EXECUTE Crea_Table"
,Merge Same Name Columns,
By matching Columns(:Lot_Day=:Lot_Day,:Lot ID=:Lot ID),
Drop Multiples(1,0),Name("Include non-matches")(1,0),
Preserve Main Table Order(1),
//No Output
Can someone help me out?
Thanks
rossjason
Re: Update existing table with new data without creating output table
Did you ever figure this out? Excel can do it...
DVLuna
I am a new JMP user, but I think I was dealing with the same issue a few weeks ago.
Please review the discussion: Updating JMP Data Tables
This discussion was an old discussion related to the issue, so I attached my questions and my final resolution to that discussion.
If it is the same issue I think I posted a resolution you can use.
Dave
Article Labels
