I agree that the plots in the last column indicate a small interaction. However, it could still be significant because I have no understanding of the noise of the system. So although this interaction is small, it may still be of relevance to you since it must be larger than the measured noise of your system. Is it still important to you? Is the magnitude of those differences noteworthy (don't forget the scale of the y-axis in making that decision). The lines are almost on top of each other because those factors (Filtration pressure and Guanidine concentration) do not have much of a main effect.
The graphs in the last row tell me the same thing except that those lines are far apart because the Protein load does have a large main effect.
The cells in the plot with a grayed out appearance are grayed out because that interaction term is not currently in the model.
Ultimately, do not confuse statistical significance with practical significance. You use the statistics (p-values) to guide you -- they do not make the decisions for you.
Dan Obermiller
