mrri
Unable to find sas documentation on JMP Virtual Lab
Hi Guys,
this might sound silly, but I'm not able to find the SAS documentation on the JMP Virtual Lab.
Does anyone know where I can find it? I have attached an image for reference.
Thanks in advance,
Phil_Kay
Re: Unable to find sas documentation on JMP Virtual Lab
So it sounds like you are using the virtual lab in the Statistical Thinking for Industrial Problem Solving (STIPS) online course - correct?
The screenshot that you attached looks like one of the Practise exercises from the module on Correlation and Regression, which you can find from the STIPS home page (see my screenshot below). Assuming that you are registered (which you would have to be to access the virtual lab), you should be able to access these materials by clicking on the different modules (at the bottom of the screenshot below).
Does that help?
to add on to Phil's reply -
there is an option to learn about using the Virtual Lab called READ ME: Getting started and instructions for using the Virtual Lab.
This will contain instructions on finding the files in the Virtual Lab for completing the STIPS course.
