I encountered an issue while working with a data table in JMP 18.2.1.
While trying to select rows, I accidentally dragged the mouse in a way that resized the row height instead of selecting. As a result, the row height became excessively large, making the table difficult to view.
The problem is that there appears to be no way to restore the row height to its original size using the mouse. Attempting to manually resize it back does not return it to the default height, and it is very difficult to achieve a consistent or clean layout again.
This behavior is quite inconvenient, especially since it is easy to trigger accidentally due to the narrow boundary between selection and resizing. It would be helpful if one of the following improvements could be implemented:
→ A simple way to reset row height to default
→ An option to lock row height to prevent accidental resizing
→ More distinct interaction between selection and resizing
Thank you for your consideration.
