Lino
URL link Is Not Working in Report
I am creating report from data table and add "Report" URL link at bottom of the report. However, the URL link is not working.
I am suspecting the way I get the URL link might be incorrect. Need community help to take a look if anything wrong on the code.
dt << Save( "$TEMP/" || Char( dt << get name )||".jmp" );
nm = "$TEMP/" || Char( dt << get name )||".jmp"; //Get URL link for the file
vb = V List Box();
dt << Get As Report;
vb << Append((dt << Get As Report));
vb << Append(Button Box("Report", Web("nm"), <<underlinestyle));
New Window ("Test", vb);
Re: URL link Is Not Working in Report
If I understand what you want, I think this code will give you what you want
names default to here(1);
vb = V List Box();
vb << Append(dt << Get As Report);
vb << save html("$TEMP/" || Char( dt << get name )||".html");
vb << Append(Button Box("Report", Web("$TEMP/" || Char( dt << get name )||".html"), <<underlinestyle));
vb = V List Box();
The original example had quotation marks around the variable name nm that were not needed -- web("nm"). I'm also not sure about the goal, but much to my surprise, the web command did re-open the JMP data table without the quotation marks.
Lino
It works. Thanks
