SpannerHead
Trying to avoid Transposition
I have a script that works but applies transposition for that to happen.  Wondering if there's a less clunky way to achieve the goal?  I have 3 columns, one contains a quadratic coefficient(a), the second contains a linear coefficient(b), and the third contains a constant(c).  When multiplied by an input variable x, I get an arc.  Is there a way to form that arc without transposing the data to do so?  Presently, I create columns with incremental changes in x in a transposed table but the data is very digital and there may be a better approach.
ax² + bx + c = 0
Slán
SpannerHead
mmarchandFSLR
Re: Trying to avoid Transposition
Something like this should work.  I added a column called "X Limit" and put a couple numbers in there.
dt = Current Data Table();
nw = New Window( "window", gb = Graph Box( X Scale( 0, 120 ), Y Scale( 0, 35000 ) ) );
For Each Row(
	dt,
	Eval(
		Eval Expr(
			gb[FrameBox( 1 )] << Add Graphics Script(
				Y Function(
					Expr( dt[Row(), "HL_HR1_R"] ) + Expr( dt[Row(), "HL_HR2_R"] ) * x + Expr( dt[Row(), "HL_HR3_R"] ) * Power( x, 2 ),
					x,
					Max( Expr( dt[Row(), "X Limit"] ) )
8 REPLIES 8
Take a look at the Y Function
SpannerHead
Thanks for this, don't seem to be able to find a decipherable example of that.  I did suspect there was a better way to do this.  Incidentally, the upper limit of X is stored in a column also.
Slán
SpannerHead
Pull values from your table to the example found from Scripting Index. Evaluate the values to the the Y Function for example with Eval(EvalExpr())
New Window("Example",
	Graph Box(
		Pen Color("red");
		Y Function(20 + 40 * Sin(a / 30), a);
Optionally you can create formula column and use Profiler
SpannerHead
Tried this but I need to raise x to the power 2 and that seems to be where it fails.
nw = New Window("window", vlb = V List Box());
For Each Row(dt,
	Eval(EvalExpr(
		vlb << Append(Graph Box(Y Function(Expr(dt[Row(), "HL_HR1_R"]) + Expr(dt[Row(), "HL_HR2_R"]) * x + Expr(dt[Row(), "HL_HR3_R"]) * Power (x, 2) ,x)));
Slán
SpannerHead
mmarchandFSLR
How does it fail?  Any error message?  Your code works when I run it on a dummy table with four rows.  I just might want to adjust the axes some.
SpannerHead
Error was self inflicted, you're right, it does plot.  I have 2 remaining challenges.
1 I would like all the plots on a single graph.
2 I would like to limit x for each plot to a value stored in another data column.  Generally, that value is >100.
Slán
SpannerHead
mmarchandFSLR
For Each Row(
	dt,
	Eval(
		Eval Expr(
				Y Function(
					x,
SpannerHead
This approach works, however, it is much slower than the transposition method I was originally using.  I can have a lot of data to process unfortunately.
Slán
SpannerHead
