simon_2
Transpose column, make transposed rows headers in JMP12
Does anyone know how to transform a column (just one column) and make the rows become the table header using JSL?
I am using JMP12.
Basically, I want the first row to be the column headers and not the output below. My dataset is attached.
Thanks,
Simon
dt = Data Table( "sports" ) << Transpose(
			columns( :Items ),
			Output Table( "transposed" )
Re: Transpose column, make transposed rows headers in JMP12
Hi, I don't have JMP 12 loaded anymore but I think all of what I used here was around in JMP 12... give this a go.
Cheers,
Brady
p.s.--we've added a lot of cool stuff since JMP 12 !!
//replicate your original table
dt = New Table( "sports",
	New Column( "Items", Character,	"Nominal",
		Set Values( {"soccer", "volleyball", "7tennis", "basketball"} ),
//get a list of desired column names.
colNameList = dt:items << get values;
If you're creating a new table: build a 1 row, n column matrix of missing data
with the J() function and the As Table() function, which lets you set column names
easily.
newDt = as table (J (1, nitems(colNameList), .), <<column names( colNameList));
//if you're overwriting onto your present table:
for (i=1, i<=nitems(colNameList), i++,
	try(
		column(dt, i) << set name(colNameList[i]) //try to change ith column name
		dt << new column (colNameList[i]) // if no ith column exists, create one
Cheers,
Brady
easily.
	try(
simon_2
works like a charm.
Thanks a lot!
@brady_brady probably provided you with better solutions, but if all you want to do, is to create an empty data table where the column names are the value from the first row, the following will do a real simple job of that
dtNew = Data Table( "sports" ) << Split(
	Split By( :Items ),
	Split( Transform Column( "Transform[Items]", Nominal, Formula( . ) ) ),
	Sort by Column Property
dtNew << delete rows(1);
simon_2
Thanks @txnelson
