If you right click a column header then select New Formula Column, you'll see a list of the formulas that JMP will automatically make for you. For me, this is about 90% of all the formulas I build in JMP. To make the formula columns in the sample table, I used this, then modified the formulas a bit in the formula editor.
To use the formula editor, right click on the header and select Formula. There, you'll see a searchable list of all the possible formulas on the left.
