Hello. I was wondering best practices for proving tool to tool matching with many factors.
For instance I have 3 tools, 2 heads per tool (a left and a right). I want to match 4 conditions for 10 parts per condition measured 10 times each.
I would normally do a GRR if it only had 3 factors. Should I just do fit model and use the variance components as metrics?
Should I just do a separate GRR for each condition then compare them?
The information I'm really trying to glean from this is if the gauges match and are capable at each condition (to some spec).
In reality, the part isn't measured at the same spot for the repeats of the measurement as it is moving. And L&R won't line up exactly to the same spots either from tool to tool. I think I can just nest those but I don't know if another method is preferred.
I attached a mock table in case it's not clear what I'm asking.
Even just recommended reading would be appreciated.
Thanks,
Vince
