barneyonion
Timestamp query for newer JMP revisions
Hi All, I have noticed that the newer version of JMP are treating the conversion of incorrectly labelled character data (which is actually numeric continuous data) slightly differently vs older software revisions. An example would be as follows:
Column called "TRANSFER_FROM_TIME" with the follow data:
00:05:36.00000
In JMP14 I used to run a script line that converted this back to H:M:S using this line.
Column("TRANSFER_FROM_TIME")<<data type(numeric)<<format("h:m:s", 12) <<modeling type(continuous);
Which would convert this into a H:M:S time format like this which worked really well.
00:05:36
However when I share this script with colleagues using updated version of JMP is appears to reference it as a "clock time" and essentially adds this onto the timestamp 12:00AM. Its almost like 00:00:00 is viewed as being 12:00AM.  So in newer version of JMP it just converts 00:05:36.00000 to 12:05:36AM.
Is anyone aware of any changes in software revisions that would have caused this to happen or a workaround to make it behave like it used to in older JMP versions.
Thanks in advance
Re: Timestamp query for newer JMP revisions
Try using duration format:
So most likely something like this:
Column("TRANSFER_FROM_TIME")<<data type(numeric)<<format("hr:m:s", 12) <<modeling type(continuous);
barneyonion
Thanks - this does exactly what I wanted.
