RA899
Test Time measurement
Hi all,
I'm not 100% sure, but I think I have seen a function that stores the run time. I need a function that captures the test time from the moment I click run until the analysis is complete. I'm using JSL. Thanks
mmarchandTSI
Level V
Re: Test Time measurement
I think most people use the Today() function for this.  For instance,
starttime = Today();
pl = {};
For( i = 1, i <= 10000000, i++,
	Insert Into( pl, i )
endtime = Today();
Print( "Execution took " || Char( endtime - starttime ) || " seconds." );
I like to use HP Time(), which works just like Today(), but it's in microseconds.
starttime = HP Time();
pl = {};
endtime = HP Time();
Print( "Execution took " || Char( endtime - starttime ) || " microseconds." );
There is also a function called Tick Seconds() that can be used
t1 = Tick Seconds();
Open( "$SAMPLE_DATA/Big Class.jmp" );
t2 = Tick Seconds();
Round( t2 - t1, 3 );
mmarchandTSI
Level V
pl = {};
endtime = Today();
pl = {};
RA899
Thank you both! Both solutions are helpful and does the job.
