tom_abramov
Level V
Terminate script running
Is there some way to terminate run of the following script without closing JMP?
Thanks.
For( i = 1, i <= 10, i++,
win = New Window( "ABC", <<modal, Text Box( Char( i ) ) );
Re: Terminate script running
Call the Throw() function when you want to exit a script without quitting JMP.
pmroz
Sometimes you can hit the ESC key and it stops JSL from running.  Operative word here is "sometimes"!
