Tenary plot customization
I'm new to JMP and using JMP Student Edition, and I've been trying to understand how customizations works in JMP, which to me seems really unresponsive.
Despite my best efforts, I'm unable to figure our why only the bottom axis label switches its font when I change axis font and the two other doesn't.
Furthermore, I do not understand why no matter what I do, it does not let me move "Raisio" or "Turku" labels like rest of the marker labels.
Thanks in advance for any help I may get
Re: Tenary plot customization
Not being able to move the labels is most likely related to the position where they are at and JMP isn't able to pick them correctly (a bug). Axis settings also seem to be quite buggy with Ternary Plot. You cannot for example right click them to access axis settings. For example in Graph Builder you have access to more options like Edit > Copy/Paste Axis Settings.
For labels you might have to workaround the issue using hover labels and pinning them
You can try to clean them up with Hover Label editor
You can also tinker around in right-click customization menu and first Force labels Label to Values then move them and then change them back to Label by Row.
