Taylor Series Linearization to Calculate Variance in NHANES
Looking at the NHANES data that incorporates demographic weightings and population stratum & PSU, is there a way to do a survey design in JMP? There is SAS code attached from the CDC below as well as R & Stata code.
https://wwwn.cdc.gov/nchs/nhanes/tutorials/Module4.aspx
Code:
SAS
PROC SURVEYMEANS data=one varmethod=taylor nomcar;
  STRATA sdmvstra;
  CLUSTER sdmvpsu;
  WEIGHT WTMEC4YR;
  DOMAIN Select;
   * more statements...;
run;
Ideally, I can get this done so that I can run the tabulate function, which I am very found of in JMP.
M. Dereviankin
ih
Super User (Alumni) ih
Re: Taylor Series Linearization to Calculate Variance in NHANES
I am not sure whether you can do this in just JMP/JSL, but JMP makes it so convenient to run R code I wonder if it is worth reinventing the wheel here. You could let R do the analysis and then bring results back into JMP to use tabulate/graph builder.
I've not tested this, but after installing R your code would look something like this:
Names default to here(1);
//Open R
R Init();
//Open your data table here:
dt = Current data table();
//send data to R
R Send(dt);
//run your code
R Submit( "\[
	# install package if needed, really only needs to happen once
	if (!("survey" %in% installed.packages())) install.packages("survey")
	#load package
	library(survey)
	#code from the website, you will want to verify column names here
	NHANES_all <- svydesign(data=dt, id=~SDMVPSU, strata=~SDMVSTRA, weights=~WTMEC4YR, nest=TRUE)
	NHANES <- subset(NHANES_all, inAnalysis==1)
	m <- svymean(~Depression, NHANES)
//return data from R
svymean = R Get( m )
//Close R
R Term();
More info on integrating R with JMP:
https://www.jmp.com/en_au/events/ondemand/mastering-jmp/jmp-and-r-integration.html
https://community.jmp.com/t5/JMPer-Cable/Getting-started-with-the-JMP-to-R-Interface/ba-p/43920
And here is some info on the R package they use:
https://cran.r-project.org/web/packages/survey/survey.pdf
